gauge problems...
Old Aug 3, 2006 | 08:36 PM
channing's Avatar
channing
Default gauge problems...
I have a 1970 mustang grande coupe. My oil, alternator, and speedometer gauges all work but my fuel and temperature gauges do not. I was wondering if anybody has posible solutions to this problem?
Old Aug 3, 2006 | 08:44 PM
289FB's Avatar
289FB
Default RE: gauge problems...
Check this probably will help you www.mustangandfords.com/techarticles/75259/
Old Aug 3, 2006 | 08:45 PM
Soaring's Avatar
Soaring
I ♥ Acer
You have separate sending units for your fuel and temperature gauges. You can test each of those sending units by unplugging them and grounding them to body or motor metal around them. If the gauge pegs, the sending unit is bad. If not, then suspect the individual gauge. Most of the time, it is the sending unit that has gone south.
Old Aug 3, 2006 | 08:53 PM
channing's Avatar
channing
thanks for your help...i am going out to check them now
Old Aug 3, 2006 | 08:55 PM
channing's Avatar
channing
i have one more question, i know the temp. switch is behind the distributor. but where is the fuel unit located
Old Aug 3, 2006 | 08:59 PM
Soaring's Avatar
Soaring
I ♥ Acer
Not sure about the 70, but check the front of the fuel tank underneath the car.
Old Aug 3, 2006 | 10:29 PM
channing's Avatar
channing
i really appreciate your help....turns out both the senders are bad
Old Aug 3, 2006 | 10:33 PM
Soaring's Avatar
Soaring
I ♥ Acer
That's usually the case. Glad you got her fixed.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
