ALT light on
Old Aug 13, 2006 | 05:49 PM
MakiMaki's Avatar
MakiMaki
Default ALT light on
Hi All,
My ALT light on my 65 Coupe is on. It always worked properly as far as i know, until this morning, it stayed on. I already had the alternator and battery checked/tested, they are fine the auto parts guy told me. What do you all think might be causing the ALT light to stay on. I ran a search on the forum but didnt find much. Im going to check all my connections and clean them up a bit, tighten down, etc. Please help if you can. Thanks.
Old Aug 13, 2006 | 07:20 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: ALT light on
If your idiot light is working properly, it is telling you that your alternator is not charging your battery. But, if you had it checked and it is OK, then yeah, you probably have a connection problem somewhere. Start with the back of your alternator, then check the solenoid, then check to see that your Voltage Regulator is plugged in good. Five bucks says your alternator is toast.
Old Aug 13, 2006 | 08:16 PM
MakiMaki's Avatar
MakiMaki
Then your out 5 bucks this time. I got lucky i guess, it was my voltage regulator. My connections werent looking so hot, but they were fine, swapped out the volt reg and problem solved (for now). Thanks.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
