pinging!?
Old Aug 27, 2006 | 07:23 AM
Volcom66's Avatar
Volcom66
Default pinging!?
what is it exactly? and is it loud?
Old Aug 27, 2006 | 09:39 AM
paddy187's Avatar
paddy187
Default RE: pinging!?
Pinging, knocking or pinking is when the fuel air mixture is ignited by compression and not the flame front produced by the spark plug see http://en.wikipedia.org/wiki/Pinging
Old Aug 27, 2006 | 10:51 AM
Soaring's Avatar
Soaring
I ♥ Acer
Very simply stated, it is pre-detonation.
Old Aug 27, 2006 | 10:58 AM
Cannonball888's Avatar
Cannonball888
Or dieseling.
Old Aug 27, 2006 | 04:28 PM
Soaring's Avatar
Soaring
I ♥ Acer
I think of dieseling as when the engine keeps running after you turn off the key, and pinging is that rattling sound you get when you put the engine under load.
Old Aug 27, 2006 | 05:58 PM
paddy187's Avatar
paddy187
run on or dieseling is preignition before the spark is fired and will cause the engine to carry on after igntion is off, pinging is pre-ignition of part of the fuel air mix and make the block into a xylophone and you hear a ping, they are similar but different
Old Aug 27, 2006 | 09:55 PM
Cannonball888
I googled it and the pinging is sound is caused by the meeting of the wavefronts of the two near simultaneous explosions occuring in the chamber---one explosion from compression and one explosion originating from the sparkplug. So, in a sense it is dieseling and a regular spark plug ignition at the same time. Pinging is the sound it makes.
Old Aug 27, 2006 | 10:01 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Cannonball888
Oh Well, at any rate. If you have either of these symptoms., you need a tune-up.
Poker at my house tonight. The dealer is wild.
Old Aug 27, 2006 | 10:33 PM
Volcom66's Avatar
Volcom66
yeah i think im done playing with it i dont want to mess it up to bad. so ill go to get a tune up soon
col2560
Dec 11, 2015 10:18 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
95_GT_Stang
Jun 10, 2005 09:36 AM
edjuk8r
Jun 7, 2005 09:17 AM
GT1999
17
Mar 24, 2005 04:18 PM
