transmission swap question
Old Aug 31, 2006 | 09:36 PM
juniorb_41's Avatar
juniorb_41
Default transmission swap question
does the v8 standard transmission for a 66 switch with the standard three speed for the inline six? if it doesnt what has to be done?thanks
Old Aug 31, 2006 | 09:37 PM
juniorb_41's Avatar
juniorb_41
Default RE: transmission swap question
that is a three speed for the v8 as well as a three speed for the I6
Old Aug 31, 2006 | 11:19 PM
mustanglover66's Avatar
mustanglover66
they do not swap, the I6 three speed is a weak a$$ piece of junk. Do you have a V8 or a I6?
Old Aug 31, 2006 | 11:26 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Is it a toploader 3-speed? If so, then it'll work behind the V8.
ORIGINAL: juniorb_41
Old Aug 31, 2006 | 11:36 PM
Scott H.'s Avatar
Scott H.
I did this back in the 70's on a fairlane.
here's what I remember doing:
fabricate an adapter plate (measured the difference in the input shaft length and made the adapter plate that thick), change the input bearing, added a clutch disc out of a Pinto (can't remember why though), I don't remember doing anything with the drive shaft. I had to cut and weld the shift lever due to the bench seat.
It was a lot of work, and I really lucked out on getting the adapter plate centered correctly (I eyeballed it and welded it to the transmisson ).
If you just need a transmission for you car, I've got a stock 3 speed in good shape you can have for free (it's going to get thrown away pretty darned soon as I'm tired of stepping over it in the garage). I live in Tracy, so you're only about an hour away. Doesn't get you any extra heft, but would save you a boatload of work and money.
Old Sep 1, 2006 | 02:46 AM
middiepride's Avatar
middiepride
toploader 4 speed, there isnt a 3 speed. there is a v8 3 speed not toploader though
Old Sep 1, 2006 | 05:39 PM
juniorb_41's Avatar
juniorb_41
the application is for an I6, and i have a v8 standard three speed. if your transmission fits an I6, scott h. i would love to take it off your hands.
Old Sep 1, 2006 | 05:48 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: middiepride
Yeah, my V8 three speed is not a toploader. The toploader is a 4 speed.
The toploader 3 speeds were used during the 1930's and 40's.
Tivo304
Aug 28, 2023 12:19 PM
97SN95GT
Sep 13, 2015 09:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
cbird1177711
Sep 2, 2015 08:51 PM
