Ever replace a 289 water pump????
I Never changed a water pump on a 289 and my book (of course) does not say much about it. It has a backing plate with a gasket and I also have another gasket with it. I assume I leave the backing plate on (which has a gasket between it and the pump) and put the additional gasket between the backing plate and the timing cover. Correct????
I'm a little confused due to the backing plate, never saw something sandwiched between the water pump and the timing cover (never replaced a ford water pump). I feel so stupid with such a simple thing..[
That is how you do it.
good point but thats what a digicam is for and second i like to replace bolts when i do projects and i usually always buy grade 8 or if its something like a valvecover or a carb i use stainless but it depends
