Door Help
Door Help
ok so a piece inside the door needs to be replaced and i cant reach it by had so i need to take off the inside of the door. it looks like the door is just one solid piece! so how do i fix a part from the inside?
RE: Door Help
well if u mean u cant fix the door by using the access holes once u take off the interior door panels you would prob have to take off the door skin....which ive never heard of someone having to do unless the door skin itself was damaged...
what are you trying to fix even? what year?
RE: Door Help
I have a 66 and i need to fix the exterior handle lever. when i pish in the handle it just moves inside the door. the screw that holds in the rod came out and i need to screw it back in but there is no way to trach it form the givin holes.
breaking
10-02-2015 01:27 PM
09-25-2015 06:58 PM
