overheating problems
Old Jul 11, 2004 | 05:17 PM
65conv's Avatar
65conv
Default overheating problems
i dont know what the problem is but my car has been running hot. i installed a new radiator recently and installed a perma cool 16 inch high performance electric fan. i also installed a new low temp themostat. my temperture gauge doesnt really work. i replaced the sending unit. when the car is started in says the temp is really low, but when i turn the car off and turn the key back to accesories the needle shoots up half way. is there anyway i can check the exact temperture without installing a gauge. i would like to fix my existig gauge and heard there should be a ground wire from the manifold to a ground, but i dont have this wire, and could that even be the problem. any help would help greatly thanks.
Old Jul 14, 2004 | 12:52 AM
68GEETEE's Avatar
68GEETEE
Default RE: overheating problems
I think the only way to really know how hot your motor gets is to run a temperature gauge on it. The stock gauge on your dash is 35 years old and is most likely inaccurate. There is a small voltage regulator for the gauges located behind the instrument cluster. This can cause your gauges to go haywire, and may need replacement. But you still need to get an actual temperature reading to really know what you have going on there.
Old Jul 14, 2004 | 03:36 AM
65conv's Avatar
65conv
thanks
Old Jul 14, 2004 | 12:11 PM
quig's Avatar
quig
This is normal as long as it cools back down when engine is running. When you turn off the car the heat from the motor goes into the coolant but the water pump is not turning so no real circulation, this makes the temperature rise once you start the car coolant is pumped through the radiator cooling it down. This shows you that your cooling system is working. Dont worry.
Quig
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
