69 351w rocker torque
Old Sep 19, 2006 | 09:58 PM
andykbob's Avatar
andykbob
Default 69 351w rocker torque
Hey Guys, I finally got my 69 going and there was a ticking coming from the valves. I asked around and some people said with a rebuild you might get some noise. So I ran it for a bit and the ticking turned into a Knock!!. So I pulled the valve covers off and noticed that on #8 cylinder, the nuts that hold the rocker in place were loose. Now I went to tightened them down and noticed the more I tightened the spring compressed.
So I was wondering if anyone knew the proper torque for these nuts?
thanks
Old Sep 20, 2006 | 12:25 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 69 351w rocker torque
You still have the stock rocker studs? I so, they can be pulling out of the head. Generally, 20lb-ft is all that you'd need for stock. If the studs are pulling out (which they tend to do), you'll never keep 'em tight.
Old Dec 1, 2010 | 12:51 AM
silbermustang88's Avatar
silbermustang88
I know this is an old thread but just in case anyone see's this:
STOP
You CANNOT simply torque rocker arms down randomly. The valves have to be in a specific position to get proper preload. This is done using the EOIC method. Look it up. Youtube has some great videos about it.
Old Dec 1, 2010 | 03:47 PM
frdnut's Avatar
frdnut
STOP
For the most part you are correct..For the original poster I believe that engine had the positive stop studs that are only threaded down so far..In that case you could simply torque them down...
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Sixer4Life
Oct 12, 2015 04:26 AM
guitarman376
Sep 30, 2015 05:54 PM
wraith777
Sep 28, 2015 10:49 AM
Sixer4Life
Sep 28, 2015 07:05 AM
