Lifters
Old Jul 16, 2004 | 06:34 PM
chelle51501965's Avatar
chelle51501965
Default Lifters
How do I adjust the lifters on my 1965 coupe?
Thanks, Chelle
Old Jul 16, 2004 | 10:48 PM
67coupe's Avatar
67coupe
Default RE: Lifters
If it has hydraulic lifters you have to turn the engine over until the lifter is off the cam lobe. Loosen the rocker arm nut and then tighten it until the tip of the rocker touches the valve stem with no clearance left. From that point you tighten the nut another 1/2 to 3/4 turn. You should probably have the engine warm to do this.
If you try to run the engine with the valve covers off be prepared to squirt oil all over your fenders. I just set the cover back on to deflect the oil for a short run to be sure there are none clicking.
Old Jul 18, 2004 | 09:31 PM
chelle51501965
Default RE: Lifters
Ok, this is the first time I have ever worked on an engine. I'm female but machanically inclined. I have done a lot of the body and engine work myself since I got the car. But, is this something I should have someone else do for me, or can I follow insturctions in a book with any questions being answered here? Because to tell you the truth, I ran my Chilton's over.
Chelle
WDScott
Aug 17, 2015 06:38 AM
ding56
Aug 14, 2015 02:40 AM
Stinger
Mar 28, 2004 09:06 PM
fasteddie
Mar 1, 2004 04:45 AM
w11988
Dec 9, 2003 06:41 PM
