turn signal
turn signal
OK so i have been helping my friend out with his 67 and we cant seem to figure out why his turn signals are not working. he have replaced all the bulbs the blue clicker thing and still no luck.
is there something that we have missed if so what?
RE: turn signal
Does it have the deluxe hood with indicators, if so you need to check them and the wiring out, they are part of the circuit. Also there's 2 clickers under the hood, one for turnsignals and one for 4 way flashers, make certain you replaced the right one. There's also a large 15-18 pin rectangular connector under the dash that has the turnsignal wiring. Its near the ashtray. You can wiggle the connectors and wires to see if thats a problem, if so, you may need to tighten the female pins, that was a problem on mine. Could be something loose in the trunk also. Just keep looking, its always the last thing you try.
Al
Al
RE: turn signal
ORIGINAL: alz
Al
Al
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
