Coat
Old Nov 20, 2006 | 03:56 PM
baddog671's Avatar
baddog671
Default Coat
What is that yellow coating called? I believe it prevents rust? Thnaks
Old Nov 20, 2006 | 04:20 PM
bronco1's Avatar
bronco1
Default RE: Coat
Hi Baddog. I believe the yellowish tint is caused by a chemical called Alodine. The bare metal is etched by an acid, then dipped into or sprayed with alodine or something similar, to help prevent corrosion. Actually I think Alodine is meant for aluminum, but the process and intent are the same.
Old Nov 20, 2006 | 05:53 PM
mlitz's Avatar
mlitz
Default RE: Coat
i think it is zinc that is what they cover bolts in and it works real good
Old Nov 20, 2006 | 06:19 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Coat
Yeah, when you go into a hardware store and get some zinc coated bolts, etc. they are that color.
Old Nov 20, 2006 | 07:39 PM
baddog671's Avatar
baddog671
Default RE: Coat
I thought zinc was silver in color, hmm[&:]....
The stupid kit isnt all the same. Some is yellow(must be zinc then), some are normal metal, and the u bolts and i bolts for the leafs are the same junk that seizes up...
jwog666
Dec 27, 2021 08:09 PM
b8checker
Oct 8, 2015 12:55 PM
Oct 1, 2015 09:29 AM
b8checker
Sep 30, 2015 07:11 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
