Bleeding Master Cylinder
Old Nov 27, 2006 | 09:00 PM
4reboy's Avatar
4reboy
Default Bleeding Master Cylinder
Ok so I have a new dual reservoir master cylinder in my car, already installed. Before I bleed the actual brakes, I need to blead the master cylinder. Now can I do this simply by hooking up the tubing and then pressing the brake pedal? or do I HAVE to "bench bleed" the master cylinder. Because if I have to do that I have to take it back out of the car, which is a real PITA.
So please someone help me out quick, can I bleed the master cylinder while its in the car?
Old Nov 27, 2006 | 09:01 PM
Yonco's Avatar
Yonco
Default RE: Bleeding Master Cylinder
I just hooked up the lines, and bled the lines and it worked fine -Jon
Old Nov 27, 2006 | 09:55 PM
Lumbergh's Avatar
Lumbergh
You can just bleed it while it is hooked up. It's preferrable by most to bench bleed before installation, but if it's already in I wouldn't want to remove it.
Old Nov 27, 2006 | 10:35 PM
Oafboy182's Avatar
Oafboy182
You could use a turkey baster. Just make sure it's not the wifes or she might kill you. I use a large plunger injector and some tubing to suck the fluid out. Like an I.V. needle only bigger and without the needle.
Old Nov 28, 2006 | 12:28 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I generally don't bench bleed my master cylinders and only bleed the system after the new cylinder is installed. Works great.
ORIGINAL: 4reboy
Old Nov 28, 2006 | 01:12 AM
4reboy's Avatar
4reboy
Thanks guys for the replies! My dad got home and we got to it. We believe our driver side rear brake has a clog in the line, and the passenger side took forever to only get some of the dirty fluid out. But we believe the front disks are almost finished, clean brake fluid is finally comming out. This takes longer than I thought.
Any tips on unclogging that line? or do we have to get a new brake line.....
Old Nov 28, 2006 | 01:22 AM
bronco1's Avatar
bronco1
Chances are, that the clog is at one of the ends, and not in the middle. Take the line loose and stick some .035 or .025 safety wire in the line to help un-clog it.
Old Nov 28, 2006 | 08:37 AM
Soaring's Avatar
Soaring
I ♥ Acer
Look at the line, and if it is rusty and cruddy looking, now would be a good time to replace it while you are bleeding the system.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
