66 4spd converting to 86 5spd
Old Dec 3, 2006 | 08:33 AM
86redrocketgt's Avatar
86redrocketgt
Default 66 4spd converting to 86 5spd
my dad is putting a 86 gt 5 spd in his 66 coupe.... his car is 4 spd now.....he asked me to post and see if anyone knows what advice to do in regards to clutch...??? 66 is shaft operated 86 is cable...is there a kit or a trickto this??? please help us to figure this one out... and which to use cable or shaft engaement??
Old Dec 3, 2006 | 01:37 PM
EmperorOfChicken's Avatar
EmperorOfChicken
Default RE: 66 4spd converting to 86 5spd
how much for the 4 speed you are taking out?
Old Dec 3, 2006 | 02:38 PM
Scott H.'s Avatar
Scott H.
Here is a great site with good information, and good pricing on parts.
www.moderndriveline.com
If you use the original top loader bell housing you can use the Z-bar. You will need an adapter to go between the transmission and the bell housing.
I'm not a huge fan of cable clutches. Some people have great success. I find they stretch when using aftermarket high performance pressure plates.
As an option to the cable clutch you can also do a hydraulic version. JMC makes a kit, or if you are good at fabrication, you can buy the components and make the brackets for a little less than 1/2 the cost. Here is a web page from a guy who did this for his '68
http://home.comcast.net/~grabblue65/Hyd_Clutch.pdf
I'm very happy with the 5 speed in my '66.
Good luck on the install,
Old Dec 4, 2006 | 06:51 PM
86redrocketgt
you talked about the spacer between the trans and bellhousing??? where can i find this or how thick does it need to be???? would like to use original stuff on car as much as possible but with better drivability. im not sure if the 4 spd is for sale either i would think not but ill ask. top loader isnt for sure but the one he pulled out was a side shift ... dont know if that makes a difference on bellhousings ?? to use rod clutch. that page on the hyd clutch is pretty good .. thanks for all of the help...
Old Dec 4, 2006 | 07:55 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
www.npdlinl.com they have conversion parts alon with www.mustangsplus.com www.mustangsunlimited.com www.mustangdepot.com etc
Old Dec 4, 2006 | 08:08 PM
86redrocketgt
wow they have kits for everything for it...thanks alot guys..im sure dad will appreciate the info very much.....seems like he has many options...thank you all
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
2poor4u2
Sep 26, 2015 11:08 AM
