arcing
Old Dec 3, 2006 | 04:28 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default arcing
i have a question if i use the original cap off of my distributor with good wire will i have arcing with my msd setup
Old Dec 3, 2006 | 05:07 PM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: arcing
If your cap is in good shape, you won't have problems. Just don't try to run any extreme plug gaps that will require the higher voltage the MSD is capable of.
Old Dec 3, 2006 | 05:42 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: arcing
That sort of negates the reason for having an MSD box in the first place, doesn't it? I know that even with the Pertronix, you can gap your plugs to about 0.045 without any arcing problems.
Old Dec 3, 2006 | 11:15 PM
Brandontyler65
I ♥ Acer
Default RE: arcing
cool i just like the look of the stock cap and second the main reason you get a MSD box is the multispark and the fact that the sparks energy doesn't diminish through the rpm range like the inductive system
daytooday
Sep 20, 2015 10:55 AM
Rhino77
Dec 19, 2007 06:34 AM
tiburon
Sep 5, 2007 03:59 PM
randyg
Dec 24, 2006 09:13 AM
kyle454ss
Aug 7, 2006 12:17 AM
