Hidden Radio
Old Dec 14, 2006 | 04:53 AM
Timelockmind's Avatar
Timelockmind
Default Hidden Radio
Anyone have pictures of your radio in the glove box? If so, I'm intrested in how you mounted it (metal bracket or wood?)
Old Dec 14, 2006 | 05:13 AM
Halz5's Avatar
Halz5
Default RE: Hidden Radio
I would definitely use metal. You could probably jsut make like a U bracket that hugs the cd player, with lil tabs on either side for bolts to go through, put some holes in the top of your glove box and if u can maybe put some kind of metal bracket on the other side of the glove box for a lil more strength. Then just drill a hole in the back of the glove box (or maybe on the top behind the cd player) to run your wires. I think that would work....
Old Dec 14, 2006 | 11:20 AM
middiepride's Avatar
middiepride
fiberglass, make it a custom mount with integrated metal tabs to hold it in. you'll get custom colors and a larger option of stuff to put in it.. Custom Autosound.comhas the radio and mounting hardware though if you want it.
www.customautosound.com
Old Dec 14, 2006 | 07:58 PM
MustangPammie's Avatar
MustangPammie
I posted a photo of mine a while back.
But, here you go again
Old Dec 14, 2006 | 10:57 PM
Timelockmind
Cool! Does the radio bracket anchor to metal above? Also is that a CD changer on the floor of the glove box?
Old Dec 14, 2006 | 11:37 PM
MustangPammie
I didn't install it myself but I believe it's bolted to metal above. It came with the Secret Audio kit but I did not get the CD changer. The head unit is mounted under the dash.
From their website, "Included with the system is a flush mount bezel for console or dash mounting. The small dimensions of the flush mount system allow you to install the LCD display almost anywhere. The LCD also comes with a bracket mount for easy installation in the glove box, under the dash, in the ashtray, sun visor, console, or wherever you choose."
The only thing I'm not fond of is the remote, as it uses radio frequencies so when I drive through the woods or certain parts of my town, it simply won't work.
And no, that's my screwdriver kit ... a girl never knows when she'll have to screw something.
Old Dec 15, 2006 | 01:27 AM
Jamison's Avatar
Jamison
heres mine kinda fuzzy though
[IMG]local://upfiles/45128/64AB17740E0F4190AEF08DD84D982181.jpg[/IMG]
kevsgt
Oct 9, 2015 10:12 PM
breaking
Oct 2, 2015 01:27 PM
vbonina
Sep 22, 2015 08:31 AM
Gkid182
Sep 22, 2015 08:17 AM
unit91
Sep 15, 2015 09:53 AM
