89 5.0 into a 66 Stang
#21
RE: 89 5.0 into a 66 Stang
also make sure your using correct balancer and flywheel / flexplate for the later model 5.0
the early motors were 28 oz and the later model (anything with a one piece rear main seal) have a 50 oz balancer and flywheel / flexplate
#23
I had to get the correct flex plate (50oz) for my setup. I had the rotating
assembly checked and balanced with the 66 harmonic balancer. I'm putting the front end (timing cover) of the 66 on the 87 block. I put a stage 1 trick flow cam in it. And using a pertronix distributor.
#25
Yes, I'm using the 66 harmonic balancer up front and a 50 oz flex plate. The speed shop had to add weight to harmonic balancer. I took the rotating assembly to them to do this. They say it's within a gram.
#26
within a gram should be fine up to 6000 maybe 6500 with stock rod bolts. for the record, the single greatest thing any of you can do while building a small block ford is to upgrade the rod bolts. drilling them out to 3/8 takes too much meat away - but going with stronger 5/16 bolts so VERY HIGHLY reccomended especially if your planning to build horsepower with your new motor.
just my 3 cents =)
just my 3 cents =)
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
