engine balancing (external)
Old Dec 21, 2006 | 02:52 PM
grruminator78's Avatar
grruminator78
Default engine balancing (external)
When getting an external balancer 28 or 50 oz do you take into account the year of the engine or the year of the mustang??
Old Dec 21, 2006 | 04:10 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: engine balancing (external)
YES
Old Dec 21, 2006 | 04:16 PM
grruminator78
[sm=chairshot.gif][sm=dontgetit.gif]yes to both???
Old Dec 21, 2006 | 04:18 PM
mayh3m's Avatar
mayh3m
the year of the engine, absolutely! the actual car is in material, that doesn't matter. i can't remember if the difference in weight is for a 289 as opposed to a 302, or if it varies by engine year. but i'm almost 90% sure it varies by engine year. my 1980 302 used the 50oz. just google search and i'm sure you'll find your answer.
Old Dec 21, 2006 | 04:29 PM
grruminator78
Yeah I googled it, but when I was looking at CHPs tech/faq page I got a little confused. For one they don't say what year the short blocks are, I guess when I order one I can tell them to throw the correct balancer in my order
Old Dec 21, 2006 | 04:36 PM
mayh3m's Avatar
mayh3m
during my rebuild process, i've learned that the guys in the summit tech support room are my best friends. so far they've answered every question i could throw at them. maybe try them? 1-330-630-0240
Old Dec 21, 2006 | 04:40 PM
grruminator78
thanks fo the tip!
Old Dec 21, 2006 | 05:32 PM
gothand's Avatar
gothand
The balance of the flywheel/flexplate much match that of the harmonic balancer. Typically, these things do follow the year of the engine. However, all bets are off with custom setups. I have a 50 oz. balancer and flywheel for my early model Mustang.
Old Dec 21, 2006 | 05:36 PM
grruminator78
So do you think this is the best course of action. Build the danged thing, write down everything I used and get some tech support after. Is there some kind of formula or something that says if you use this year block this kind of flywheel or flexplate, this kind of tranny this kind of etc. etc. etc. get this kind of balancer??
Old Dec 21, 2006 | 05:53 PM
gothand's Avatar
gothand
What are you trying to build and what parts do you already have? If you're building an early engine and are sticking with the v-belts, make it easy on yourself and stick with the early balance so that everything still lines up properly. If you're building a 5.0L then stick with the late model balance. As long as you match the early balance dampener with the early model flywhee/flexplate or late model with late model, you'll be fine with respect to balance.
