LITTLE PROBLEM...
Old Dec 26, 2006 | 05:27 AM
ADRIAN1's Avatar
ADRIAN1
Default LITTLE PROBLEM...
my car drives fine, but when it comes to stop and go traffic theres a little problem. When i take my foot of the brake pedal and tap the gas, my car stays accelerated for about 1 or 2 seconds then goes back to normal idle? this just started happening so I dont know what to check or do! please help...
Old Dec 26, 2006 | 11:12 AM
85lebaront2's Avatar
85lebaront2
Default RE: LITTLE PROBLEM...
Is it an automatic? If so it may be the dashpot is set a little too high. It is designed to keep the throttle from slamming closed on automatic trasnsmission engines. It will be a small round device on the front left (driver's) side of the carburetor. The throttle lever contacts it at idle. There should be a locknut on the front side of it, loosen that and turn the dashpot in slightly, maybe 1/2 turn and retighten the lock nut. Try it and see if it helps, but not so far the engine "stumbles" when you tap the gas and let off it quickly.
fablefifty
Dec 29, 2006 10:32 PM
x9Mustang9x
Dec 14, 2006 02:20 PM
Airman21
Nov 17, 2006 04:10 AM
XXC
Sep 19, 2006 05:12 AM
mstng675l
May 25, 2005 03:02 AM
