Coil Spring Help
Old Jan 6, 2007 | 01:14 PM
  #21
428coupe's Avatar
428coupe
Default RE: Coil Spring Help
I placed my other "new" spring beside the wore out 6 cyl. spring I took off to compare the heights of the two, the are nearly identical. The newer spring has a larger wire diameter. So I guess they are not too long. Anyone have any new thoughts?
[IMG]local://upfiles/40458/A26D9AD50A7047A19297763E5459AF70.jpg[/IMG]
Old Jan 6, 2007 | 01:29 PM
  #22
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
lets hope that works
Old Jan 6, 2007 | 02:25 PM
  #23
JamesW's Avatar
JamesW
I think it looked all pooched out because the lower arm wasn't connected to the other parts and it allowed it to swing down lower than usual.
Old Jan 6, 2007 | 06:11 PM
  #24
ponyx2's Avatar
ponyx2
Its too long. The perch rotates as the spring compresses or extends. I just did mine and with the upper control arm unsupported and laying on the frame the spring should not bow like that.
Old Jan 7, 2007 | 11:00 PM
  #25
Spring Guy's Avatar
Spring Guy
The springs on my 68 coupe with a 302 use a 5/8 bar diameter and has 8.5 total coils. I count 9 and 9.25 total coils on the springs in the picture. If the pictured sprngs are 5/8 bar diameter and have 9 and 9.25 total coils those springs are weaker than what I am using and may be from a 6 cylinder.
Old Jan 8, 2007 | 12:53 AM
  #26
428coupe's Avatar
428coupe
The springs I took off measure to be 0.58 inch diameter (9/16") I assume they are the factory springs and this was a 6 cyl. car, the springs I am installing are 0.625 inchdiameter (5/8"), they were purchased last year.
Unless I was given the wrong part (which has happened before), these should be for a V8. I don't know if there is a difference between big block and small block springs, but I ordered springs for a 68 Mustang with a 390/428.
Old Jan 8, 2007 | 02:07 PM
  #27
Spring Guy's Avatar
Spring Guy
I would think there is a difference, Good luck
firehorse02
Nov 16, 2015 11:28 AM
mungodrums
Sep 28, 2015 10:54 PM
Sixer4Life
Sep 28, 2015 07:05 AM
lmurf60
Sep 24, 2015 10:07 PM
