Dim Gauge Lights 73 Convert
Old Jan 5, 2007 | 11:00 PM
mikeofwarr's Avatar
mikeofwarr
Default Dim Gauge Lights 73 Convert
The instrument panel lights are real dim, including the heater panel lights. It seems like I recall there is a regulator(?) that controls the voltage to the panel lights or could it be the headlight switch.The headlight switch will dim the lights all the way, but they will not get very bright. Is there a different bulb that could be used (ie. lower voltage so it would burn brighter), currently the bulb used is a 194. I hate to just start replacing parts.
Old Jan 5, 2007 | 11:02 PM
enzedchris's Avatar
enzedchris
Default RE: Dim Gauge Lights 73 Convert
i say look into switching to some LED's in the back of it. even on the lowest setting they are bright as hell due to how efficient they are. they last forever [basically] too
Old Jan 6, 2007 | 04:56 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Remove the green/blue lenses that block the light.
Old Jan 6, 2007 | 05:00 AM
enzedchris's Avatar
enzedchris
ORIGINAL: Colorado_Mustang
that would work, although it looks kinda nasty without those
Old Jan 7, 2007 | 06:35 PM
bodyputtyless's Avatar
bodyputtyless
The trouble is you get conditioned to the lights inside modern car dash boards, then when you drive your classic it looks dim.
Old Jan 7, 2007 | 07:35 PM
enzedchris's Avatar
enzedchris
ORIGINAL: bodyputtyless
i reckon, u ever seen those new volkswagens, bloody bright as hell, i heard it's sposed to keep you from fallin asleep at the wheel
Old Jan 7, 2007 | 08:07 PM
Soaring's Avatar
Soaring
I ♥ Acer
Here is a good article on why they are dim, and how you can brighten them up.
http://www.boss302.com/cluster.htm
Old Jan 7, 2007 | 09:50 PM
mikeofwarr's Avatar
mikeofwarr
Thanks for all the replys. The article provided by Soaring is great. My lights are way too dim to see at night, so it is not just the differnce between the modern car and the old Mustang. I will post when I resolve the problem.
Nick Oliver
Oct 17, 2018 04:22 AM
spamedic
Sep 9, 2015 12:15 AM
zachary1988
Sep 4, 2015 03:04 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
amandahchase
Sep 3, 2015 10:09 AM
