Bodywork coming along
Old Jan 8, 2007 | 02:39 AM
valley firearms's Avatar
valley firearms
Default Bodywork coming along
Skim coating and sanding! Hopefully the car will go to prime next week since we are only working on it during the weekends. I am working on the corner of my trunk as some of you may remember. I cut the steel from an old computer shell. I used a whitney punch to pop all the holes in the patch which were then spot welded. I then used bondo-glass to fill it in. If any of you are doing bodywork, I suggest you try this stuff. It is like kitty hair and it is much stronger than the regular bondo. It actually has fiberglass strands in it.
My fiberglass hood was bowed pretty bad in the middle along the sides. I used a piece of 3/8" X 2" X 3' steel bar to fix it. I bounced on the steel to put a bow in the middle. I then reverse clamped it onto each side of the hood drawing the bow down with 5 C-clamps so the hood flattened out. Then I took a torch and heated the steel and top of the fiberglass. After it heated I could hear the resins poping and cracking. Pretty scary at first. I thought my hood was going to explode. I took some cool water and ran it over the heated areas. After the hood cooled I took the clamps off and it stayed! I thought of this all on my own and it worked. I suppose someone will tell me that my hood will crumble within a year now [8D]
Anyway, when the car is painted I have a long road ahead of me putting everything back together. I never thought I'd strip the car as far as I did for paint.
[align=left] [/align]
[IMG]local://upfiles/21693/204F52369AF14060BAF25E0E63077E29.jpg[/IMG]
[IMG]local://upfiles/21693/B04EDBF272044727AD899CE39DEE9F8B.jpg[/IMG]
[IMG]local://upfiles/21693/3DAE6C2E903F46C28A57E0249B4E08D7.jpg[/IMG]
Old Jan 8, 2007 | 02:55 AM
green_blurr's Avatar
green_blurr
Default RE: Bodywork coming along
that kinda looks like my problem .
[IMG]local://upfiles/43944/36ABAC34E9144D8DAB9B4ABC34EAB956.jpg[/IMG]
Old Jan 8, 2007 | 03:09 AM
valley firearms
Yikes, I feel your pain. That damn metal is thin and will burn through when you weld it. Can you drill holes around the outside of the hole and hold a patch up under it and spot weld? Then use that bond-glass to cover it. That is my suggestion. Maybe someone has a better one. I hope you are using a wire feed with argon. Good luck.
Old Jan 8, 2007 | 03:23 AM
green_blurr
actually that hole was brazed i heated it up and it melted out
Tivo304
Aug 28, 2023 12:19 PM
bjdutch2005
Mar 24, 2017 03:38 AM
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
uedlose
Sep 10, 2015 03:30 PM
tmdm
Sep 4, 2015 06:45 PM
