Different types on POSI?
Old Jan 8, 2007 | 08:11 PM
Yonco's Avatar
Yonco
Default Different types on POSI?
Right now my 9 inch has 3.73's and its OPEN. I have the rear off now and would like to put in a posi, BUT. What type? I hear of many diff kinds ie. true-trac/ trac-LOK/detroit locker and more. What would be the best bang for the buck? I know some are all GEAR and some are clutch. But whats the most reliable? Where is a good CHEAP place to get one? Can i pick one up for 250$ i see a few on ebay NEW for 225$ -Jon
Old Jan 8, 2007 | 08:24 PM
THUMPIN455's Avatar
THUMPIN455
Default RE: Different types on POSI?
If you will be racing or beating on it regularly...
These
http://store.summitracing.com/egnsea...115+4294902618
or these..
http://store.summitracing.com/egnsea...115+4294819097
If you are just cruising around, have a low powered engine and wont race it often, nor beat on it with sticky tires, then you can get by with these.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=PWT%2D1810%2DLR&amp ;N=700+4294925134+4294908331+4294839047+4294918887 +4294900976+4294902536+115&autoview=sku
After building rear ends with minispools, and cheaper drop ins, then putting them behind a high torque engine, I have found its cheaper to do it right the first time than throw $200-$300 at it every 6 months to a year. The differential takes a huge amount of abuse from normal driving, add performance type things or racing and things will break eventually.
I tend to overbuild now, that way I dont have to fix it again while I own the car. I own them for a long time too.
Old Jan 9, 2007 | 02:25 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I like Detroit Lockers....
Old Jan 9, 2007 | 02:41 AM
Cannonball888's Avatar
Cannonball888
true-trac
Old Jan 9, 2007 | 03:14 AM
bradleyb's Avatar
bradleyb
would detroit vs. tru-trac kinda like the comparison above?
Old Jan 9, 2007 | 04:42 AM
atomsk680's Avatar
atomsk680
ORIGINAL: Colorado_Mustang
+1
Old Jan 9, 2007 | 01:38 PM
gothand's Avatar
gothand
ORIGINAL: atomsk680
+1
That is a locking differential, not a posi. For a limited slip (posi), they'll all wear out, faster with heavy use, with perhaps the exception of the Tru-trac. I've had friends use them and Jeeps and think they were okay for a limited slip. However, they pulled them out and went to full lockers as limited slips are pretty useless for Jeeps on the rocks.
FWIW, I've had limited slips, automatic locking diffs (detroits, ez-locker) and manual locking diffs (ARB). For a street vehicle, you will be making a compromise on ride with an automatic locker. You'll hear things like "it is hardly noticeable" or "you get used to it." The bottom line is that it is noticeable and it is a necessary evil to gain that traction. IMO, a limited slip is perfectly adequate for all street driven vehicles and I wouldn't go to an automatic locker unless you were a racer or had other driving styles that would otherwise prematurely wear out the discs in a limited slip.
2007CalSpec
Dec 13, 2020 11:42 AM
kevsgt
Oct 9, 2015 10:12 PM
guitarman376
Sep 30, 2015 05:54 PM
mrappe
Sep 26, 2015 10:16 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
