Pertronix
Old Jan 23, 2007 | 11:31 PM
bw71mach1's Avatar
bw71mach1
Default Pertronix
I've been looking into getting a Pertronix system to replace my original points system. I see there is a Pertronix and Pertronix II. Is the number II worth the extra money? Also should I get the coil that goes with it? One has 40000 volts and II has 45000 volts. What is the best option for a 1971 351C. What are the benefits.
Old Jan 24, 2007 | 12:22 AM
richmond20657's Avatar
richmond20657
Default RE: Pertronix
check out ford muscle they have a duraspark conversion on there that may be cheaper and better
Old Jan 24, 2007 | 12:35 AM
67Sally's Avatar
67Sally
Pertronix for the win. I'm not sure about the difference between the 2 and 1 but you'll definitely need the new coil. It'll be fine on that engine. You'll get a bunch of benefits because it is just all around better than the stock points. There's tons of info online about them.
Old Jan 24, 2007 | 11:19 AM
grruminator78's Avatar
grruminator78
http://www.pertronix.com/
it tells you the difference. basically [*]Compared to the original Ignitor develops an average 3 times more available energy between 3000 and 5000 RPM and nearly doubles available plug voltage.
Old Jan 24, 2007 | 11:48 AM
dozierstang's Avatar
dozierstang
+1 on the Pertronix. Best upgrade I did to my engine. I am sure I did the Pertronix I. And definately get the coil that goes with it. Might as well get the spark plug wires too.
Old Jan 24, 2007 | 11:56 AM
shr's Avatar
shr
has anyone used the D.U.I.system on their cars, its a all in one HEI unit?
Old Jan 24, 2007 | 11:58 AM
sxs191's Avatar
sxs191
Get the Pertronix Ignitor II. The 45,000 volts ignition coil and at least 8mm plug wires. You'll be glad you did. Piece of cake to install.
Old Jan 24, 2007 | 01:20 PM
plainsmen's Avatar
plainsmen
ORIGINAL: sxs191
+1... I ended up getting the whole shabang on Ebay last year..
Flamethrower II
Pertronix 7mm Plug Wires
All for 165.... best deal out there
Here's a current auction for the EXACT same listing I bought last year
Pertronix Ignitor II, Flamethrower II, 7mm plug wires ~ $165 & FREE Shipping
Try to find them all for that price individually
Old Jan 24, 2007 | 01:23 PM
plainsmen's Avatar
plainsmen
Here's also a link for the same seller with the regular
Pertronix I, Flametrower I, and 7mm plug wires for $135
I looked at that one too.... but decided I might as well spend the extra 30 bucks and get the newer II's.
Old Jan 24, 2007 | 02:29 PM
my77stang's Avatar
my77stang
isnt 7mm wires kinda cheesy though?
