Now i am Thinkin gears
with a 3 speed or 4 speed without overdrive, be it manual or automatic, the top gear cruise rpm will be the same, as they are all 1:1 ratio when they are not an overdrive.
AOD is an overdrive, so it can take a bit more gear out back and not have the RPM hangin around 4000 or so doin 75 mph on I-80 through the lonely stretches of Nebraska or Nevada..
Simple way to find out approximately what RPM you will be turning at a given speed with a certain tire and rear gear is this.
Using math here so if you need someone to explain it, that can happen.. dont feel bad if you dont get it.
(rear gear x 336 x trans ratio) / (tire diameter x rpm) = MPH
or..
(4.10 x 336 x .72 ) = 991.872 or rounded 992
(26 x 4000 rpm) = 104000
Divide 104000 with 992 and you get 104.8 mph.. provided there is no slippage in the drivetrain.
Now the .72 is the overdrive ratio, lets see what happens when we use a 1:1 gear in the trans, like a 3 or 4 speed..
(4.11 x 336 x 1) = 1380.96 or 1381
(26" tire x 4000 rpm) = 104000
divide and it equals... 75.30 mph
So then the OD in an AOD is worth almost 30mph in extra cruise speed for that RPM.
(3.0 x336) = 1008
(26 x 2000) = 52000
= 51.58 mph cruise MPH
(3.55 x 336) = 1192
(26 x 2000) = 52000
= 43.62 mph
So the difference at 2000 rpm between a 3.00 gear and a 3.55 gear is 8.38mph
336 is a constant sorta like Pi, you know 3.14..
or..
(3.0 x336) = 1008
(26 x 2000) = 52000
(3.55 x 336) = 1192
(26 x 2000) = 52000
= 43.62 mph
ORIGINAL: THUMPIN455
Muggsy, you could have a 3.55 pumpkin, a 4.11 pumpkin, and a 3.00 pumpkin, all set up and eaqsy to swap. If one doesnt work for you, the other will untill you want to change something again. Just get junkyard carriers, the 3.00 gears can be a stock set with a posi in them, and then you have a choice. If you do more highway driving, swap in the 3.00, if you wanna go racing, put in the 4.11 or 3.55 and see what difference it makes on ET.. it doesnt really cost that much to set up three or four 3rd members and have them sitting around. Old refrigerators work good for storage.. it only takes about half an hour to swap them, and a bit of lube.. no big deal.
ORIGINAL: Soaring
Ah Thumpin, go put some used tires on top of your trailer house, and put out some plastic pink Flamingoes in you front yard. Nobody has that kind of space to keep old pumpkins like you do.
KingRando
Oct 2, 2015 08:06 AM
junior04
Sep 28, 2015 10:53 AM
