shelby drop question
Old Jan 29, 2007 | 11:29 PM
bradleyb's Avatar
bradleyb
Default shelby drop question
I drilled the holes per the template and the upper control arms fit in quite nicely - there is only 1 problem - the shock tower has a little lip and the nut is hitting the lip???? Has anyone else ran into this problem - did you guys grind or bend down the shock tower piece, did anyone just use a couple of washers to get enough distance to clear? What is the recommended approach here? Where the old holes used to be, there is no lip but when I moved the holes down, it is hitting that lip up at the top.
Would appreciate thoughts here, thanks.
Old Jan 29, 2007 | 11:43 PM
2bav8's Avatar
2bav8
Default RE: shelby drop question
The lip will crush easily when you tighten up the nuts.
Its a common occurance and is not a problem.
Old Jan 29, 2007 | 11:46 PM
bradleyb's Avatar
bradleyb
Thanks 2bav8, I should probably use a washer anyway to keep from mangling the por-15 finish on the engine compartment anyhoot
Old Jan 30, 2007 | 12:56 AM
JamesW's Avatar
JamesW
If it bothers you, take a grinder to it and smooth it just enough to clear the nut.
Granatelli Sales
Jan 20, 2020 12:34 AM
9550
Oct 26, 2015 05:01 PM
04stangman
Sep 17, 2015 01:45 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
zanemoseley
Sep 6, 2015 12:58 PM
