convertible reservoir
Old Jan 31, 2007 | 05:05 PM
orion's Avatar
orion
Default convertible reservoir
Does any one know where the convertible top reservoir is on a '67 convertible. I dont want to start pulling everything apart unless I have to. I've had the car 34 years and never checked it! Its only now giving me a problem.
Old Jan 31, 2007 | 09:02 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: converible reservoir
its behind the seat where the top folds to (also i believe the motor/ lift cylinders have been the same since the 60-90's in case u need a new one)
Old Jan 31, 2007 | 09:54 PM
orion's Avatar
orion
Thanks for that, do you know if it's easier to pull the seatback out or do you have to remove the vinyl 'sheet' that's attached to the back of the seat, with what looks like dozens of small screws?.
Old Jan 31, 2007 | 10:38 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
id remove the seat back personally but u have to remove the bottom also its up to you the plastic liner is reffered to as the well liner
Old Mar 1, 2007 | 10:42 PM
RJM763's Avatar
RJM763
The rear seat just pulls up. Grab the front of the back seat where your knee bend when sitting on it. Put your hand on the bottom where the seat meets the carpet and pull up. The bottom should just come up. Now there are two small screws that hold the back of the rear seat on. Remove those two srews and the back seat moves up and off of two clips at the top.
good luck
Joe
cr620
Oct 3, 2022 10:18 PM
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
