Speedometer Goes reverse direction HELP!
Old Feb 14, 2007 | 07:59 PM
joed's Avatar
joed
Default Speedometer Goes reverse direction HELP!
Could anyone tell me how to fix this? My 65 Mustang 6 cly, 3spd manual transmission has a speedo problem. I just bought this car and the old owner was no help. The problem is the speedo goes toward the Omph instead of showing proper road speed. It actually goes in the reverse direction, and it is driving me crazy which is a short trip.
Thanks in advance for any help!
JOE
Old Feb 14, 2007 | 08:27 PM
restomod66's Avatar
restomod66
Default RE: Speedometer Goes reverse direction HELP!
The gear has the wrong direction. Type 3 or 3a. I believe you need a type 3a on you car.
Old Feb 15, 2007 | 12:02 PM
grruminator78's Avatar
grruminator78
maybe your car is from oz
Old Feb 15, 2007 | 12:03 PM
Wisconsin 5.0's Avatar
Wisconsin 5.0
Just drive in reverse!
Old Feb 15, 2007 | 02:35 PM
kalli's Avatar
kalli
it would drive me nuts as well.
you'd be better off disconnecting it from the dash until fixed.
Old Feb 15, 2007 | 02:39 PM
mustanglover66's Avatar
mustanglover66
Someone probaly put a 4 speed gear on the cable. The 4 speed is the only trans. with the cable mounted on the passanger side of the car. get the correct cable gear and it should be fine. you will need to try to figure out how many teeth you need on the gear though. check NPD catolog they have the gears and the foumala to figure it out.
Old Feb 15, 2007 | 03:14 PM
NorCalTroy's Avatar
NorCalTroy
Just curious... does the odometer go backwards?
http://www.imdb.com/title/tt0091042/
Old Feb 15, 2007 | 04:23 PM
kalli's Avatar
kalli
no. they're usually made in such a way that odometer only goes forward.
Some even increase when you drive backwards.
So the only way on cheating with the odometer is to make it overturn (50000->99999->00000->25000 ...)
Old Feb 15, 2007 | 04:36 PM
NorCalTroy's Avatar
NorCalTroy
I was making a joke in reference to the movie Ferris Bueller's Day Off (the movie referenced in the link). I figured the odometer wouldn't go backwards, but couldn't miss the opportunity to bring up the movie. If you haven't seen it, it's a great movie from the 80's.
jwog666
Dec 27, 2021 08:09 PM
articman
Jun 21, 2018 11:45 PM
marc954
Sep 29, 2015 03:05 PM
kartracing87
Sep 28, 2015 11:01 PM
popsotto
Sep 28, 2015 06:58 AM
