crate motors
Old Feb 18, 2007 | 11:13 PM
mustanglover66's Avatar
mustanglover66
Default RE: crate motors
ORIGINAL: EmperorOfChicken
holy crap mustang lover, yalls prices are low!!! thanks guys. we'll keep in touch mustang
And lnulike jegs, summit and abunch of others our engines are custom built not assemblyline built. which means you tell us what you want to do with it and we will design an engine to do it. but it does take a little time currently 6 to 8 weeks.
Old Feb 18, 2007 | 11:31 PM
my77stang's Avatar
my77stang
I think balanceand good internals is the key, stud girdles and 4 bolt mains helps also
yuppers, +1 on that
Old Feb 18, 2007 | 11:47 PM
superdavid's Avatar
superdavid
Another +1... balance is everything... vibrations=bad...
Old Feb 19, 2007 | 01:21 AM
white69mach1's Avatar
white69mach1
ive hear rhr performance builds realy good motors that who im planing on going with for my 408 u should check him out no prices on his website you will have to send him emaile and he will get back with you
Old Feb 19, 2007 | 12:54 PM
69mach1377's Avatar
69mach1377
ORIGINAL: mikethebike
Now, if you want to build that kind of hp with a 302 use the 5.4 in rod with the Ford hp 302 block, steel crank, GT-40 big valve head, roller rockers, 700 cfm Double-pumper, the right manifold, Hooker Super-Comp headers and you won't need to spend the extra money for other drive-line parts to hold the 400 lbft of torque the 347 or 406 will build. Plus you will save the weight of those parts. And let's face it...having your red-line at 8000 IS kind of fun.
Funny...no mention of this magic cam that can do all this. 8k rpm? Pass that doobie around man...
Old Feb 19, 2007 | 03:49 PM
67Thunder's Avatar
67Thunder
When goofing around as a kid, I had the opportunity to break a couple street motors. The last motor (small block) I built for the car had been set up to withstand 500 - 550 hp, balanced to 8,000 rpm. It had a solid lifter cam, which you could take to 7K, but really was 2400 -6600 power band.
Build it stronger than you need, and use a good street cam. Unless you're racing, a nice performance hydraulic street cam, and then you don't have to worry about over-revving, or adjusting lifters.
Old Feb 19, 2007 | 04:01 PM
gothand's Avatar
gothand
ORIGINAL: 67Thunder
[sm=goodidea.gif]The 351W I pulled out of my '65 had a solid lifter roller cam that worked great and revved high, but was a drag to adjust after awhile. From that experience, I came to the realization that for me, there is such a thing as too much power for a street driven '65. My new motor is a 'milder' 302 with 375/394 and it is still difficult to put it to the pavement. Even with the full Global West suspension, I'm not totally confident in its manners like I was with my later model GT's. YMMV.
Maybe I am getting old.
firehorse02
Nov 16, 2015 11:28 AM
UrS4
Oct 3, 2015 06:23 AM
Explosive
Oct 2, 2015 07:45 AM
Drastang
Sep 30, 2015 03:48 AM
logan409
Sep 26, 2015 07:43 PM
