Shelby Drop?
Old Mar 1, 2007 | 02:40 AM
  #21
68SCode4speed's Avatar
68SCode4speed
Default RE: Shelby Drop?
Cool - didn't know they already had thought of it. GW stuff is so nice that it doesn't surprise me.
Old Mar 1, 2007 | 03:02 AM
  #22
gothand's Avatar
gothand
ORIGINAL: 68SCode4speed
Yeah, good stuff.
Unfortunately for those wishing to do the Shelby drop, I just measured the jig and Global West drops the upper arm 1.75".
Old Mar 1, 2007 | 05:41 AM
  #23
paddy187's Avatar
paddy187
http://www.opentrackerracingproducts.com/droptemplate/is john dinkel's template
Old Mar 1, 2007 | 02:37 PM
  #24
AndysJeeps's Avatar
AndysJeeps
I just ordered the metal template for the Shelby drop. That will lower car about 1/2", with stock tires could I lower it about another 1/2" with a lower spring and do OK with the tires not rubbing?
I removed the power steering pump from the car when I was changing the water pump, I'm waiting on the link that by-passes the piston now.
Does anyone have any knowledge of removing power steering from their Mustang. Eventually I want to install rack and pinion.
Old Mar 2, 2007 | 09:46 AM
  #25
mikethebike's Avatar
mikethebike
ORIGINAL: gothand
FWIW, my Global West suspension also came with a steel template similar to that above. It really mad it kind of foolproof. I'm pretty sure I still have it, so if somebody in the L.A. area ever wants to borrow it, shoot me a message. Heck, I guess I could probably mail it somewhere as well. I'll double check the measurements to make sure they use the same geometry, but I'm pretty sure it is.
I like my Global-West!! NO understeer...at-all!!
Old Mar 3, 2007 | 12:54 AM
  #26
Scott H.'s Avatar
Scott H.
Old Mar 4, 2007 | 11:44 PM
  #27
Mustang Dad's Avatar
Mustang Dad
Well, for better or worse, it's been done. Got the upper arms de-mounted and the hole drilled and the arms back on and tightened down.
The springs have been re-mounted, just waiting to install the shocks and the wheels/tires to check it all out leter this week.
Old Mar 5, 2007 | 12:10 AM
  #28
baddog671's Avatar
baddog671
ORIGINAL: Mustang Dad
pics!
Old Mar 5, 2007 | 01:07 PM
  #29
AndysJeeps's Avatar
AndysJeeps
OK we drop the upper mount, should the old holes be covered or supported in any way?
This drop should work with standard coils am I right, I don't know if I want a harder ride than stock, but I do want better cornering.
Old Mar 6, 2007 | 10:25 PM
  #30
baddog671's Avatar
baddog671
ORIGINAL: AndysJeeps
I was thinking about that the other day. A couple rubber grommets would do well I should think...
