AOD Block Plate question
Old Mar 2, 2007 | 01:12 AM
a_stone_def's Avatar
a_stone_def
Default AOD Block Plate question
For those of you that did the AOD swap did you use your stock C4 block plate or by the one from Ron Morris or another vendor?
Old Mar 2, 2007 | 02:20 AM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: AOD Block Plate question
i havent done it but i believe that you have to buy one for the AOD
Old Mar 2, 2007 | 02:48 PM
iamdiffrnt's Avatar
iamdiffrnt
I haven't done it yet either....Hoping the plate for my pan fill C-4 will work (164 tooth)
Old Mar 2, 2007 | 09:20 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
just get the one from the donor car and for the flexplate u need a 28 balance flexplate so pick up one from the parts store for a 71-73 351 car with the fmx tranny it will have the correct toooth count 164 and should be compatible with the aods torque converter
Old Mar 2, 2007 | 09:22 PM
deadcarnahans's Avatar
deadcarnahans
ORIGINAL: iamdiffrnt
The pan fill (164T) will work but the access cover bolt patern is different.
Whenever I buy a tranny I try to get the plate that came with it. Get one from the junk yard.
Old Mar 2, 2007 | 09:45 PM
LCC's Avatar
LCC
I used the same flex plate from theC6 and bolted the AOD right up. The engine was 351C but the bolt patterns forC4 and C6 to AOD are the same.
Old Mar 3, 2007 | 01:22 PM
a_stone_def
So does any one know if these Flexplate and Blockplates are the ones I need?
Flexplate:
http://cgi.ebay.com/ebaymotors/SBF-F...spagenameZWDVW
Blockplate:
http://cgi.ebay.com/ebaymotors/Musta...spagenameZWDVW
Old Mar 4, 2007 | 01:07 AM
deadcarnahans
ORIGINAL: a_stone_def
Flexplate:
Blockplate:
The blockplate looks nice. I'll sell you a used one for 1/2 of that.
Old Mar 4, 2007 | 01:22 PM
a_stone_def
Hey dead, Ill take your blockplate can you take paypal and ship it asap?? Please PM me.
Old Mar 5, 2007 | 01:58 PM
a_stone_def
What does everythink about that flex plate? Is that the right one??
04stangman
Sep 17, 2015 01:45 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
96stang3.8
Sep 10, 2015 06:42 AM
Sep 8, 2015 05:21 PM
