My car is alive, and its not that great.
Old Mar 8, 2007 | 08:05 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: My car is alive, and its not that great.
ORIGINAL: Soaring
Open the hood and with the engine off, try replicating the same problem by hand. You may find that the linkage is binding because it is bent, or your return spring is weak.
+1 but id do it with the car on jackstands in the rear and with the car in gear like u were driving it
Old Mar 9, 2007 | 12:28 PM
66mjchiara's Avatar
66mjchiara
I removed the old return spring and installed a new one last night. The car seems to be doing ok but im still apprehensive, she is very crafty. I will put some more miles on her tonight and see if she is still in control.
Old Mar 9, 2007 | 12:30 PM
66mjchiara's Avatar
66mjchiara
Motor mounts look fine i see little to no wear on them.
Old Mar 9, 2007 | 02:38 PM
SportyStang66's Avatar
SportyStang66
ORIGINAL: NorCalTroy
Check for a broken motor mount. The motor will twist just enough to bind up the throttle rod. I remember another thread similar to this one and that was the cause. You could probably do a search and find the thread. Good luck!
I had the exact same problem years ago. It was the motor mount. I can't recall if I could visually see the failure, but your symptoms are vey familiar.
Old Mar 10, 2007 | 01:55 AM
az1966's Avatar
az1966
return spring,,is number 1 !!!!!...exhaust flange to arm......after that look at ( AND I KNow ) it's crazy but nylon washer for the choke/clear issue.........Just got by the same friggen issue,,it's deff a link issue
Old Mar 14, 2007 | 10:46 PM
66mjchiara's Avatar
66mjchiara
Just wanted to say thanks to those who replied, your comments helped greatly. I had installed a new return spring a little under a week ago, and the demon is no longer. I have complete control over acceleration. I bought a return spring from a local auto shop and its rigged up pretty shotty. I am missing the return spring bracket so for the time being I had to coil one end of the return spring around a bolt that the previos owner was using as some sort of custom bracket. So far it runs fine but fixing this is on the top of my to do list. Any recommendationg on an accelerator bracket or would anyone be fine?
Old Mar 15, 2007 | 07:43 AM
andrewmp6's Avatar
andrewmp6
glad to hear you got it fixed having a throttle sticking isnt safe
Old Mar 15, 2007 | 12:51 PM
NorCalTroy's Avatar
NorCalTroy
A cheap little throttle return spring beats having to swap out a motor mount any day. They sell aftermarket brackets at just about any good auto parts store. I'd make it the number one fix on the list... cheap, easy and dangerous if you don't!
KEM Motorworks
Aug 14, 2015 10:13 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ponyride00
Aug 12, 2015 01:57 PM
