help with ignition
Old Mar 24, 2007 | 01:00 AM
eZ's Avatar
eZ
Default help with ignition
well i got the 65 running today. finished the tranny and all the linkages. problem i ran into is that the ignition is dead. i replaced my alternator with a single wire alternator. i beleive i may have hooked something up wrong. all i did was install the single wire to the positive side of the selinoid. the other wires are not hooked to anything. turn the key and there is nothing. hot wire starts the car right up though.
on another bad note it seems that because my car sat for a year that the carb needs to be rebuilt now. its a brand new carb that was fired a year ago and then sat. the accelerator pump does not work nor does the choke. rebuild it?
thanks for the help.
Old Mar 24, 2007 | 01:03 AM
66JameStang's Avatar
66JameStang
Default RE: gonna need guidance
Give the carb a couple of days to "soak up", It might start working ok, I have done this before without issue. Who knows, you might get lucky!!
Old Mar 24, 2007 | 02:52 AM
eZ's Avatar
eZ
maybe omarrow il take some pictures of how the altenator is wired so you guys can give more help
Old Mar 24, 2007 | 02:57 AM
gothand's Avatar
gothand
My carb sat for eight years and worked great at first start up. Have you checked the level in the fuel bowls yet? You can replace the accelerator pump and fix the choke without rebuilding the carb.
Old Mar 24, 2007 | 02:59 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Not sure on the alternator thing...but my carb sat for 7 years and works fine. Still going to rebuild it though
Old Mar 24, 2007 | 03:14 AM
Colorado_Mustang's Avatar
Colorado_Mustang
You have the alternator hooked up correctly, and it's time for a carb rebuild.
As for the ignition problem, you need to find which wire gets 'hot' with the key in the 'ON' position. This wire goes to the 'I' terminal on the solenoid. The wire that gets hot when in the 'Start' position should go to the 'S' terminal.
If you can't find these wires, you'll need to trace back toward the key to find the break in the wire.
Old Mar 24, 2007 | 03:58 AM
67t5ponycoupe's Avatar
67t5ponycoupe
"the other wires are not hooked to anything" If this is true this is your problem. You still have to power up the rest of the systems on the car. All those wires that went to the positive side of the solenoid need to be hooked up to get power to the fuse block.
Old Mar 24, 2007 | 04:12 AM
JMD's Avatar
JMD
Sorry, I have not studied the stock charging circuit yet, honestly I dont know just what goes through the regulator and how it goes through. I know I will need to know soon when it comes time to upgrade the alternator to an internally regulated system.
I will take a look at it tomorow, and if you don't get some answers from more some folks who are moreimformed than me, I will give it a shot! I have confidence that someone will step up to the plate though!
Old Mar 24, 2007 | 02:15 PM
eZ's Avatar
eZ
my S and I terminals are hooked up the same as they where before.
Old Mar 24, 2007 | 02:18 PM
eZ's Avatar
eZ
im on my way home now and ill take some pictures before i go up to work.
