I got another leak...
Old Apr 14, 2007 | 09:23 PM
johnson0031's Avatar
johnson0031
Default I got another leak...
Hi Guys,
I noticed fluid on the inside rear tires, in a radial pattern. Not sure what it is, brake fulid maybe, any ideas? I have drum brakes, they have always sucked, but I do not see a change in performace. Could it be something else?
I have a 67 convertable with a 289, pretty much stock. I was considering upgrading the front brakes to disk, maybe adding a booster. I was planning to leave the rear breaks alone.
Old Apr 14, 2007 | 09:44 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: I got another leak...
Take your drums off and see if the brake cylinders are leaking. That's the only thing it could be since your axle bearings are sealed. Look at and smell the fluid. Brake fluid has a distinctive smell and burned 90 weight rear end fluid smells like rotten eggs. The thickness of the fluid will also give it away as brake fluid is thin compared to differential gear oil.
Old Apr 14, 2007 | 11:56 PM
woodywrkng's Avatar
woodywrkng
I had this last year, and it was indeed the rear axle seal. The seal is on the outside of the bearing, and rear end lube was getting through the bearing. Easy to replace.
Maddsajin
Aug 6, 2014 10:06 PM
hell-damage
May 27, 2013 01:41 PM
LavaRedMCA
May 8, 2013 08:31 AM
baddog671
Jul 15, 2012 09:25 PM
hpwrestler220
Jul 24, 2010 12:44 PM
