HELP 67 289 engine issue
Old Apr 15, 2007 | 05:20 PM
paddy187's Avatar
paddy187
Default RE: HELP 67 289 engine issue
surely it's always a false economy being low grade for the wife......especially if she finds out....
Old Apr 15, 2007 | 05:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: rst08tierney
Ok crazy. I found a tangled spark plug wire last night before I closed up the engine last night. This morning I took the car out and It had no problems all the way to the gas station (almost a mile.) I filled up the tank with 7 gallons on 91 and now the car has never run this good EVER.(not to mention it has a bran new carb)My question is was it the wire? Or was it the car not having enough gas?Im in sunny California so its not cold, and I just installed a new 800 cold crank batt.This is my first build, so if my questions seem weak im a rookie.
Also I usually put in the cheap 87 because its my whifes car[:@]will 91 make a differenc since its only a 289? It felt like it did....
It was the wire sparking over to another wire. You still had 9 gallons of gas left in the tank so it could not have been low fuel. Even if the fuel was low, remember that backfiring is caused by an ignition problem, not a fuel problem.
Old Apr 15, 2007 | 08:45 PM
rst08tierney's Avatar
rst08tierney
got to love it. took the car back out later today and the same problems all over. I think im going to start at my mallory box, it seems to be the oldest part of my engine at this point.
Old Apr 16, 2007 | 03:49 PM
silverbullet69's Avatar
silverbullet69
I have a Mallory Unilite distributor in my 302, and had the same problem once... tried everything i could think of. It wound up being the darn center of the distributor cap on the inside.Instead of it being a fixed piece that makes contact with the rotory button, its a piece with a spring under it..... The spring would stick and make it lose contact with the rotory button every now and then, making it backfire.I opted for the whole cap, don't know if i could've bought just that once part in the center.Anyway, i had rebuilt the carb and lots of other stuff before i figured out that one!!
Old May 6, 2007 | 03:14 PM
rst08tierney
My problem EXACTLY!!!!!! It was the dam cap.......
djbigskrilla
Sep 20, 2022 01:04 AM
ChampInSD
Oct 2, 2015 04:55 AM
kdryan
Aug 21, 2015 04:01 PM
ding56
Aug 14, 2015 02:40 AM
mweiland
Aug 13, 2015 05:11 PM
