aGas
Old Apr 20, 2007 | 01:50 AM
66GTKFB's Avatar
66GTKFB
Default RE: aGas
What an optimist. Do you remember Sunoco 260?
Jim
Old Apr 20, 2007 | 07:51 AM
andrewmp6's Avatar
andrewmp6
Default RE: aGas
you could try it if its too low of a octane it will spark knock which can be fixed with timing or bottle of octane booster
Old Apr 20, 2007 | 10:26 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: aGas
ORIGINAL: eholzer07
How can I find my compression?
Basically, you pull all the spark plugs and use a compression gauge to check. Here is a how-to tech article.
http://www.motorage.com/motorage/art...l.jsp?id=16170
Old Apr 20, 2007 | 10:33 AM
my77stang's Avatar
my77stang
Default RE: aGas
I ran 100Low Lead avitaion gas in my old 289 once. It didn't like it very much.
really? my 302 LOVED the av gas, hell it liked it better than the sonoco 110 or 117 i'd feed to it.
eholzer all you gotta watch for when going to a lower octane is if your motor starts rasping and pinging. if that happens, drive easy to the next gas station and top that thing off with premium
Old Apr 20, 2007 | 11:44 AM
Hornblower's Avatar
Hornblower
I ♥ Acer
Default RE: aGas
A 9:3.1 comp ratio 289 will run just fine on 87 octane. The 10:1.1 needs the 91-93 and the 11:0 needs upwards of 93 octane. It would take a lot of upgrades to get a 289 to 11.
Old Apr 20, 2007 | 11:58 AM
dr1965's Avatar
dr1965
Default RE: aGas
ORIGINAL: Hornblower
the 9;3.1 I agree, but do you think it would run"Better" on higher octane?
Old Apr 20, 2007 | 12:09 PM
Hornblower's Avatar
Hornblower
I ♥ Acer
Default RE: aGas
ORIGINAL: dr1965
It may even run worse. It might seem odd that fuels with higher octane ratings explode less easily, yet are popularly thought of as more powerful. The misunderstanding is caused by confusing the ability of the fuel to resist compression detonation as opposed to the ability of the fuel to burn (combustion).
Old Apr 20, 2007 | 12:56 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: aGas
A lot of guys waste money on fuel thinking that high octane fuel is better for their engines. Knocking or pinging is generally caused by the timing not being set right, not the octane of the fuel. Although the octane of the fuel does lead to pinging in the higer compression engines.
Old Apr 20, 2007 | 03:45 PM
superdavid's Avatar
superdavid
Default RE: aGas
ORIGINAL: my77stang
Yeah, but that was with a stock 289. I think the higher compression on my 408 would possibly burn it a little better.
Old Apr 20, 2007 | 05:46 PM
Brandontyler65's Avatar
Brandontyler65
I ♥ Acer
Default RE: aGas
eh i fill up with 89 after i put my cam in it ran like crap with 87 in my 289
iraqvet
Dec 18, 2012 07:14 AM
wrightm
California Regional Chapter
Oct 7, 2011 12:44 AM
venezuelanmustang
Nov 5, 2007 04:02 PM
firemedix911
May 16, 2005 09:45 PM
