steering box
Old May 6, 2007 | 12:58 PM
supermanzx9r's Avatar
supermanzx9r
Default steering box
how to take shaft off of steering box 67 nonpower steering
Old May 6, 2007 | 03:32 PM
66GTKFB's Avatar
66GTKFB
Default RE: steering box
I think that a 67 is a short shaft version of a 64 to 66 steering box. With a big wrench or a big pair of channel locks, undo the lock nut at the shaft end. Then undo the bearing adjuster nut. At this point, get a copy of the 67 Ford Service Manual or you will have lots of ball bearings and other parts going all over the place.
Jim
Old May 6, 2007 | 03:39 PM
JamesW's Avatar
JamesW
This is something that cannot be done why the box is installed on the car, and should be left to a specialist.
http://www.stangerssite.com/HowItWorksSteeringBox.html
Old May 6, 2007 | 04:10 PM
66GTKFB's Avatar
66GTKFB
Excellent link. That's pretty much how I adjusted mine, but explained well.
Jim
Old May 6, 2007 | 06:20 PM
supermanzx9r
great link i just need to get it out so i can install a powersteering unit i have a the parts from a 67 power steering unit but it looks like i will need a new steering colume
Old May 6, 2007 | 09:02 PM
mikethebike's Avatar
mikethebike
1st..do you have a coupler? (rag joint)..if not you need to remove the entire box and shaft. Good luck.
Old May 7, 2007 | 09:42 AM
supermanzx9r
hey mikethebike or soaring will this work for my power steering setup
http://cgi.ebay.com/ebaymotors/1968-...13081920QQrdZ1
ORIGINAL: mikethebike
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
ChampInSD
Oct 2, 2015 04:55 AM
