Cylinder heads
I'll talk slower so you understand Jim.
The C code 289 has 9.3:1 compression ratio. The A code 289 has 10.0:1 compresion ratio. You get more compression by having smaller chambers, so the A code chambers are smaller than the C code heads.
There's dished pistons, domed pistons, notched pistons for valve clearance, flat top and many combinations of them. Part of the calculation for combustion chamber size is the deck height. It's not easy to measure except on flat tops, so when you cc heads you also need to cc a cylinder on an engine stand so the head surface is perfectely horizontal and the piston is at the top. The head gasket is also in the equation. All that volumn plus the bore and stroke make up the compression ratio formula. I helped out a bow tie guy blueprint a B/MP engine many years back. Sometimes you learn from the 'enemy'.
Jim
Jim
ORIGINAL: Brandontyler65
a code engine had flat top pistons c code had 5cc dish
As I sit here in 72 degree weather, I'm sipping some burgundy and looking at the Ford Car Parts book and low and behold, there are different pistons for 2 barrel engines and 4 barrel engines for 289, HP is a different issue. The low compression 4V in 64 1/2 uses the 2V in 65 to 68. They do not list compression ratios. Do you want the section, page and part number?
Jim
Jim
