67 radio problem
Old May 21, 2007 | 06:55 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default 67 radio problem
Hey i bought a 1967 Mustang about a week and a half ago and the radio is not connected. Supposedly it is the original radio but the person before us put a sony cd player in it. I want to rewire the original can you guys give me some tips. Or a diagram or something to make it easier.
Old May 21, 2007 | 07:28 PM
Mustangdemon67's Avatar
Mustangdemon67
Default RE: 67 radio problem
im sure you can find the diagrams somewhere online, but if you cant i got some at home that illscan when i get off work.
Old May 21, 2007 | 07:37 PM
Soaring's Avatar
Soaring
I ♥ Acer
You have two wires coming out the back. One is the positive wire that you hook up to a switched 12V source such as the black and blue wire coming off your ignition. The other is the negative and can be hooked to any negative source. You will need to take your gauge cluster out to get to it.Then you hook the antenna cable to it and you will have AM radio if it still works.
Old May 21, 2007 | 09:29 PM
1slow67's Avatar
1slow67
ROTM Moderator
The mustang i have had an Am/Fm radio in it when I bought it. I can put pics of it on here if needed.
Old May 21, 2007 | 09:59 PM
66GTKFB's Avatar
66GTKFB
Glen, Slow down. A two pin connector for the speakers, a two pin connector for hot switched and panel lights,antenna and maybe a ground.
Jim
Old May 22, 2007 | 12:51 PM
1slow67's Avatar
1slow67
ROTM Moderator
It there a specific way to plug it up to the plugs?
Old May 22, 2007 | 01:45 PM
66GTKFB's Avatar
66GTKFB
Coming out of the radio, the speaker connector is polarized, one male one female - the power connector has two male pins and you should match the wire colors although the pins may be a different diameter. The black-red tracer wire is for the lights, yellow-black tracer wire is switched power. If the speaker is beyond use, replacements are available, about $13.00.
Jim
Jim
Old May 22, 2007 | 03:09 PM
1slow67's Avatar
1slow67
ROTM Moderator
Thank you guys. I now have a working radio in my mustang. And it actually sounds pretty good.
vbonina
Sep 22, 2015 08:31 AM
Gkid182
Sep 22, 2015 08:17 AM
Beerman309
Sep 19, 2015 01:16 AM
unit91
Sep 15, 2015 09:53 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
