clearance issue
Old May 23, 2007 | 08:40 PM
farkedup's Avatar
farkedup
Default RE: clearance issue
ORIGINAL: Soaring
I'll bet that rubber bushing burning was a nice scent to your nose. I used a sawzall, and others have used air wheels to get that friggin front bolt out. The one on the driver's side on mine just slipped right out, but the passenger side had to be cut out. Hard and nasty work isn't it?
I used a sawzall too... I used the torch to cut the leafspring up fairly close to the end so that I wouldn't have a big leafspring in my way of cutting. Even using the sawzall it took a LONG time to get out. It just kept melting and was a really nasty job to do.
I'm very eager to get my mustang back together LOL I'm single again so I want to drive this car as much as I can! My 9" rear I think was from a '72 mustang. I used the FAQ to find one that was the right size. I can't remember exactly what I got my rear axle from. I'm using 04 bullitt rims which are 17" I just really like that style. Its not chrome so I think they look real nice.
Old May 23, 2007 | 08:50 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: farkedup
ORIGINAL: Soaring
Yeah, I was under there maybe an hour on that friggin bolt because I had to cut it twice. I used 5 new blades. You will be very happy with the new springs and the ride height they give you. I went with the 4 leaf standard leaf because I didn't want to lower it anymore than it was. The reverse and mid springs will lower the car, and the 4 1/2 or 5 leaf springs will make the rear very stiff.
Factory is 4 leaf for a good reason.
Old May 23, 2007 | 08:58 PM
gothand's Avatar
gothand
ORIGINAL: 66JameStang
Well I actually bought the nine inch from Currie for my year of mustang,. So I thought it should be exactely or close to the size of the stock setup. They only touch on the top of the fender. the wheels do stick out but only slightly the tire is 8" wide..
The front drivers side does rub slightly on the front but I am gonna modify it to take care of the problem. it is very minor.
Since both your front and rear are rubbing, I'd bet that your wheels are the culprit. My 9" was re-done by Currie and they narrowed it to '65 specs, 57-1/4".
BTW, stiffer springs will only mask the problem. Eventually you will hit a big enough dip in the road and your suspension will compress enough to contact the tire with the body unless you extend your bumpstops to ensure that does not happen.
Old May 23, 2007 | 09:31 PM
66JameStang's Avatar
66JameStang
ORIGINAL: gothand
What are bumpstops? Do they make it bottom out before hitting the rear fender.
Old May 24, 2007 | 02:09 AM
mat11089's Avatar
mat11089
The front bolts on mine were stuck like crazy too and i used an air hammer with 100psi and knocked out with no sweat.
Old May 24, 2007 | 05:14 AM
andrewmp6's Avatar
andrewmp6
bumpstops should stop it from bottoming out the suspension but they are right they are a bandaid on the problem either roll your fender lips or fender flares
Old May 24, 2007 | 09:04 AM
Norm Peterson's Avatar
Norm Peterson
Like the name suggests - they stop the 'bump' motion, whether it's the axle going up or the chassis coming down. At the rear, I think it's more to keep the shocks from bottoming out internally (which will ruin them) and/or the axle tubes from crashing into the chassis itselfthan preventing tire rub.
New shocks will help, if the old ones are shot. Not enough damping means that either the axle or the car will be moving more than it should over any given bump. Probably best to replace them along with the springs anyway.
Norm
Old May 24, 2007 | 12:19 PM
66JameStang
ORIGINAL: Norm Peterson
Norm
I replaced the shocks when I did the rest of the suspenssion. I but kyb gas adjusted shocks in the car. Thank you very much I will look at it and see what is the next step I am definately going to replace the leafs at this point.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
