hmm whats wrong?
Old May 25, 2007 | 09:47 PM
  #21
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: hmm whats wrong?
ORIGINAL: DenDen
I think the problem is in the idle screws.When they are not feeding equally on both sides this will happen.Adjust them by turning them in to where they are tight,count how many turns it is.It should be around 2 full turns out each side.Im betting there is a difference in the amount of turns you find.
Ah come on Denis. My idle adjustment screws on my 2100 are at least a full turn apart and my engine runs like a banshee indian.
Old May 25, 2007 | 09:51 PM
  #22
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: ponyx2
Either the needle has a piece of trash on it in the carb or the float is sinking. Just my .02
If the float is sticking, it will flood out and gas will be evident on top of the intake. If the needle has any trash in it, the car won't run at all.
On edit: I see that Pony is saying the float is sinking and could cause the problem. If the float is sinking, it has a hole in it and will not allow any gas into the carb bowl. If that is the case, then take the carb apart and shake the float. You will hear it if the float is full of gas.
Old May 27, 2007 | 02:14 AM
  #23
yleefox's Avatar
yleefox
ORIGINAL: chps77
whats a booster? and surging?
[/quote]
The booster is the large, round, canister shaped part that is behind the brake master cylinder. It has a vacuum hose routed to it. Surging is when the idle speeds up and then drops, the speeds up and then drops.
Yleefox
Old May 27, 2007 | 01:45 PM
  #24
pinboy122's Avatar
pinboy122
Start with the easy stuff.Change your fuel filter.Change your vac lines too.I dont think its your idle adj screws because the car was running fine before.
Old May 27, 2007 | 01:56 PM
  #25
chps77's Avatar
chps77
got up the next day, the engine was very cold.. started up without any probs and ideled fine without the up and down idel thing... hmmm "shurgs"
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
marc954
Sep 29, 2015 11:18 AM
