my77stang is right about the size. If you are having a valve job and the valves need replacement you can have 1.94/1.50's installed for almost the same cost.
yep i sure will, for now i was just testing out my simdyno
i stuck with the 1.84 1.54 in my 351w heads because it will help with low end nut. go too big and you loose it in the bottom - but i did extensive machine porting to open things up under the head of the valve.
