engine dies
Old Jun 26, 2007 | 01:08 AM
  #21
maverick75's Avatar
maverick75
Default RE: engine dies
Well it fire right up today
I put a 1 gallon tank to the fuel line under the drivers door...tuned the carb richer...
....but then the carb would not stop squirting fuel even after it died
While it was running i remembered i left the charger hooked up, and when i went to go see it it was rattleling because of the engine and it almost fell, it would have probably shorted and burned up like my other one did...when i finally unhooked it i couldn't find my screwdriver to adjust the carb(engine was a 4K) when i found one the engine died...
....then i found out i forgot to hook up the tranny lines
so what makes the carb squirt fuel like crazy?I rebuilt it about a month ago.
http://www.youtube.com/watch?v=wgmPN1iOsxs
Old Jun 26, 2007 | 09:38 PM
  #22
maverick75's Avatar
maverick75
ORIGINAL: maverick75
Anyone?
Old Jun 26, 2007 | 09:50 PM
  #23
66GTKFB's Avatar
66GTKFB
Stuck float.
Jim
Old Jun 26, 2007 | 09:57 PM
  #24
maverick75's Avatar
maverick75
ORIGINAL: 66GTKFB
Stuck float.
Jim
thanks now that i remember when i was filling up the fuel bowl the float did get stuck and i forced it down....hope i didnt break anything.
Old Jun 26, 2007 | 10:54 PM
  #25
toolwench's Avatar
toolwench
Same thing I'm dealing with in my '66 Vette. Sunk float. I pulled and cleaned the needle and seat just to make sure there wasn't anything it preventing it from closing. Then, throughout the time working on the car, I kept adjusting the float--to...uh...get it 'right'. Except that in my quest to get it adjusted, I chased the float as it sank completely. Turns out, it's plastic and I've never had luck with them staying afloat. The good news is that they're pretty easily replaceable.
I'd check your needle and seat--make sure it's free of debris. If gas still spews, you've likely got a problem with your float. I'd start by adjusting it, but if adjusting it doesn't seem to help, replace it.
Old Jun 26, 2007 | 11:35 PM
  #26
maverick75's Avatar
maverick75
Thanks...i never adjusted it( i just turned the hex nut all the way down), looks like mine is a bronze not plastic.
1TUFF302
Nov 5, 2015 04:02 PM
67LimeCoupe
Sep 30, 2015 04:46 PM
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
