engine pull
Old Jun 27, 2007 | 08:55 PM
64to66's Avatar
64to66
Default engine pull
Any tips on where to attach to pull the engine? I have the balance bar for the hoist and plan on pulling the whole shebang tranny and all. I have a 1966 i6
thanks!
Old Jun 27, 2007 | 09:54 PM
deadcarnahans's Avatar
deadcarnahans
Default RE: engine pull
Any bolt holes you can get to.
Old Jun 27, 2007 | 10:24 PM
Stevetra's Avatar
Stevetra
On this forum I have learned 2 ways...carb plate or exhaust manifold bolts.
I have aleays used the intake manifold bolts....but that was on a chevy.
I was assuming I would use the intake bolts when I pull mine...but idk.
Old Jun 28, 2007 | 12:00 AM
69stangcoupe's Avatar
69stangcoupe
i read that pulling an engine from the bolts will damage the holes.
Old Jun 28, 2007 | 12:05 AM
scuf23's Avatar
scuf23
Check the FAQ section - there are some links with good information on this topic
Old Jun 28, 2007 | 12:35 AM
gothand's Avatar
gothand
If you're using a load leveler, they use four connecting points to the engine. I use the holes in the cylinder heads that the accessories bolt to. Make sure you thread them in enough and you won't have any problems.
Old Jun 28, 2007 | 12:44 AM
my77stang's Avatar
my77stang
yup, thats what i always used - one chain, back of head on one side, front of head on the other side, hook in the middle and YANK!!!!!!
Old Jun 28, 2007 | 01:09 AM
64to66's Avatar
64to66
Okay! i'll let you know how it goes!
Old Jun 28, 2007 | 03:40 AM
andrewmp6's Avatar
andrewmp6
being a inline 6 you want 2 chain on each side of the back good luck and be carefull.69stangcoupe it can if done wrong i have pulled many engines as long as you thread the bolts all the way in its fine.
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
zachary1988
Sep 4, 2015 03:04 PM
Sep 1, 2015 08:16 PM
