65 Mustang 289 Severe Engine Knocking
Old Jun 30, 2007 | 10:19 PM
mashie2001's Avatar
mashie2001
Default 65 Mustang 289 Severe Engine Knocking
My 65 Mustang has severe engine knocking. I suspect a blown rod, but I'd like to be sure before I pull the motor to get it rebuilt or buy a new one. First thing I've didwas check the engine oil. It has oil, but it looks thick.Does anyone knowwhat else could be causing the loud knocking. Was told one optioncould be oil pump.
Thx
Old Jun 30, 2007 | 10:29 PM
67mustang302's Avatar
67mustang302
Default RE: 65 Mustang 289 Severe Engine Knocking
"knocking" could be anything depending on what you define knocking as. Could re rod bearing, main bearing, piston slap, detonation etc. Need more description of what it's doing
Old Jun 30, 2007 | 10:37 PM
mashie2001's Avatar
mashie2001
It's very loud and I can feel it at the bottom of my feet when sitting in thedrivers seat.Soundsand feels likea hunk of metal is hitting another hunk of metal.
Old Jun 30, 2007 | 10:42 PM
67mustang302
Does it get louder/quieter when you give it throttle or get out of the throttle? Sounds like it's prolly gonna be a rod bearing
Old Jun 30, 2007 | 10:45 PM
mashie2001's Avatar
mashie2001
Louder and the frequency increases.
Old Jul 1, 2007 | 04:27 AM
Sean W.'s Avatar
Sean W.
i think maybe the rings broke on one of the pistons and the piston is slaping around in the cylinder...
take the oil pan off and see if there are chunks of metal.
either wat i suggest you take the oil pan off and inspect the oil.. see where you are from whats is in the oil.
Old Jul 1, 2007 | 12:25 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
Pull the pan, see whats kicking there. If you can't see anythying untoward there go ahead and pull the engine and do a post mortum on it. I recently had a similar occurance with my NEW 351w. It turns out that the machine shop didn't hone out the #1 cylinder properly and there was a tight spot about halfway down the cylinder bore. One quick trip to the high side of 6500rpm and the piston and cylinder wall were scorched. Rehoning the bore and a new piston and I was back in business so I didn't have to pull the engine.
Old Jul 1, 2007 | 12:46 PM
Soaring's Avatar
Soaring
I ♥ Acer
At this point it doesn't really matter what it is. It's obvious the engine needs to be taken apart and inspected.
ShaneB26154
35
Mar 4, 2021 04:05 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
inyadreems
Aug 21, 2015 09:10 AM
ding56
Aug 14, 2015 02:40 AM
daytooday
Aug 11, 2015 09:22 AM
