Carburator Question
Does this brown wire going to the fan have power during starting? Soaring, you mention advice on electronic ignition on a post. Can you tell how I should wire the elctronic ignition I'd appreciate it.
There is no power during starting and you don't want any. The choke is closed as it should be to aid in starting, and as the resistance wire in the electric choke heats up (it heats up faster at 12V than at less), the choke opens, or it will when you trip the fast idle cam and all the other little stops.
If I remember correctly (text messaging is not for adults), Glen probably recomended the Pertronix I system, and I do too. I got one in my 66 hardtop daily driver back-up car and a whole bunch of little nagging problems went away.
Jim
Jim
Jim i did the installation like you said. Carb is installed, it gets power from the dirty brown wire.
When i start her up now the engine runs like crazy. How do i slow it down ?
If the choke is still engaged after five minutes of being heated, you need to figure out why it hasn't tripped back to normal idle speed (it could be jammed), adjust its high idle speed (a normal adjustment), or see if theregular butterflys are somehow jammed open. All this can be done without the engine running, one of the positive features of an electric choke.
Jim
Jim
ORIGINAL: quinchem
http://www.fordmuscle.com/archives/2...ix/index.shtml
ORIGINAL: 66GTKFB
Jim
Jim
ORIGINAL: michaeldoggrell
Mine does the same at start up. If you give it a small stab on the gas pedal, it will settle a little. It will still idle high though until it is warmed up, or you step on the pedal hard.
To adjust the idle speed on the carb, there is a screw on the lower right side of the carb. If you watch the video from the link I posted earlier, it will show it to you and show you how to adjust it.
ORIGINAL: bluovalguy
Not sure which section it is in, but is under installation 1,2,3, or 4.
http://www.edelbrock.com/automotive_...ech_vids.shtml
These vids are straight from the dvd.
