fuse box layout
Old Jul 11, 2007 | 01:14 PM
Loza_69Mach1's Avatar
Loza_69Mach1
Default fuse box layout
Hi everyone, I have a 1969 ford mustang mach 1... and my lights inside dont work on the dash only. All my others work.. So before taking the dash apart i wanted to check out the fuse. So i found the fuse box under the dash on the drivier side. Does anyone know if thats where the fuse go for those types of lights? Is there another fuse box. And where can i get a picture of the fuse box so i can found out what fuse im looking for? thanks again.....
Old Jul 11, 2007 | 01:38 PM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: fuse box layout
Before sweating the fuses, try twisting the light switch **** right or left to see if they brighten. Someone may have put them on very dim.
Old Jul 11, 2007 | 01:45 PM
Loza_69Mach1
i ve tried that and nothing.... what else.. you think... are the fues the next step... im not sure what fues is where ...
Old Jul 11, 2007 | 01:47 PM
Soaring's Avatar
Soaring
I ♥ Acer
Pull them out one at a time and inspect them.
Old Jul 11, 2007 | 01:49 PM
Loza_69Mach1
mmmm.... ill try that.... thanks
Old Jul 11, 2007 | 02:25 PM
66GTKFB's Avatar
66GTKFB
The fuse in question is a 14 amp located in the upper left corner of the bus block. A more likely scenerio is the ground on the instrument cluster circuit board. This is a common problem with 69 and 70 instrument clusters. It's not easy to fix.
Jim
Old Jul 11, 2007 | 06:28 PM
dnswwood's Avatar
dnswwood
All good Ideas.Hope it isnt what it was on my 70.All the bulbs were blown and the plastic circuit on the back was fried.Do all your gauges function?I understand you have no lights behind them,but do the actual guages work? If not then it may be the plastic circuit on the back of the insturment panel.
Hope this helps
Jeff
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 2, 2015 04:12 PM
