Custom throttle linkage complete
Old Jul 15, 2007 | 11:48 PM
19stang66's Avatar
19stang66
Default Custom throttle linkage complete
So I finally got the motivation to do something this weekend. After realigning my hood and installing the hood pins I decided to make a custom throttle linkage. I got the directions from this site, http://www.fordmuscle.com/archives/2...kage/index.php. I didn't follow their directions exactly though. Instruction #6 says to cut the brake line to length. I thought it was a bit early to cut the brake line since I didn't have the rod measured to my desired length. So I did #6 last. I also used 3 grades of steel wool to polish the brake line and heim joints. Trust me, if you want the assembly to look great without painting go the steel wool route. I also plan to clear coat the assembly so it won't rust. I noticed a big improvement in acceleration and feedback without any sloppiness from this new linkage compared to the other one I had. Totally worth the $20 I spent on everything!
The supplies.
Close up of step washers and spherical rod end.
Close up on NAPA part #'s.
Before and after steel wool.
I used the chrome step washers the article suggested, but I bought them off ebay. Much, much cheaper.
This rubber washer was already there from my old linkage. I found two washers in my garage to stiffen this particular assembly.
Where it attaches to "bell crank" arm
Old Jul 16, 2007 | 02:50 AM
Soaring's Avatar
Soaring
I ♥ Acer
Default RE: Custom throttle linkage complete
Man, that's amazingly clean work. You need to clean your thumbnail though.
Old Jul 16, 2007 | 07:12 PM
19stang66's Avatar
19stang66
Thanks for the compliments guys. I thought my thumbnail looked too clean, I just guess it was that easy of a mod[sm=smiley20.gif]
Old Jul 16, 2007 | 08:00 PM
19stang66's Avatar
19stang66
Well if you are going to do that I spose I should give a little more info. My carb is a 4160 Holley and this is where I got the stepped chrome washers:
http://cgi.ebay.com/ebaymotors/ws/eB...33713&rd=1
When that link becomes dead you can just search under carb bushing or carb link bushings and something should show up. Also if you don't like ebay you can get them here, http://store.summitracing.com/partde...p;autoview=sku or search under carb bushing on the Summit Racing site. You have to buy two of them because there is only one in each package. Two bushings come in a package but only one will work.
Also I couldn't for the life of me find those self tapping screws with the rubber and metal washers on them. That is why I decided to get the stepped bushings. I also had to special order the spherical rod ends from NAPA and they were the most expensive part even with the big discount I got. And the rod ends are fine threads so you will need a fine threaded rod and hex nuts, they also state this in the material list on the Ford Muscle website I posted earlier.
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
LivingInThePast
Sep 16, 2015 12:20 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Webster454
Sep 7, 2015 04:59 AM
