Light Recommendations
Old Jul 21, 2007 | 07:35 PM
DCStang65's Avatar
DCStang65
Default Light Recommendations
My taillights, headlights, blinkers (both front and back) are really dim. Almost been creamed a few times by drivers who don't know I am braking or changing lanes. Any recommendations on lights to use to pump things up?
Old Jul 21, 2007 | 07:55 PM
JamesW's Avatar
JamesW
Default RE: Light Recommendations
Headlights - Install a headlight relay system http://midnightdsigns.com/james/headlights.htm
Taillights and turn lamps - 1) disassemble and clean lamp housings. 2) polish with steel wool, or even paint with a high temp chrome paint. 3) Replace bulbs and lens with new.
Replace headlamp switch.
Inspect, clean and retighen all wire harness grounds tied to lamp harnesses.
Old Jul 21, 2007 | 08:31 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
I would check the grounding strap from the engine to the frame and clean all connections. The fact that all your light circuits are dim points to a system current handling problem.
Old Jul 21, 2007 | 08:32 PM
Uncle Leo's Avatar
Uncle Leo
I saw some replacement LED tail lights in a catalog and thought that was a good idea. Haven't gotten that far on mine yet, but when I do I think it's an intriging idea and will seriously consider it.
Old Jul 21, 2007 | 11:44 PM
Astrawn's Avatar
Astrawn
I have wondered this myself. It seems all classic cars have dim lights, tail, head interior, etc...I guess cause they are classics. Does anyone upgrade to brighter bulbs or anything? I thought about installing the indigo guages so I could see them better at night.
Old Jul 22, 2007 | 12:44 AM
connor90's Avatar
connor90
ive heard the LED tail lights are amazing and you can get them for like $80 on e-bay
Old Jul 22, 2007 | 02:37 AM
andrewmp6's Avatar
andrewmp6
led are briter and last longer but cost more.
Old Jul 22, 2007 | 05:19 AM
coda618's Avatar
coda618
Before you start thinking about LED, make sure your electrical system is checked. If your stock stuff is not performing properly, new fangled LED, etc are not going to do to well either.
+1 on the procedures mentioned above. You can also get brighter tail light bulbs. I think the 1157 bulb is available as 2057, which is brighter (no mods req'd). Have your alternator tested and voltage regulator. Clean ground and connections, etc.
Good luck.
jhawkr
Oct 30, 2015 01:55 PM
nboost
Sep 16, 2015 05:35 AM
Colin Ringle
Sep 15, 2015 09:27 PM
Blk Vert
Sep 9, 2015 12:16 PM
amandahchase
Sep 3, 2015 10:09 AM
