gap between wheel and caliper
Old Jul 27, 2007 | 01:40 AM
mySAVIOReigns's Avatar
mySAVIOReigns
Default gap between wheel and caliper
I put together my granada disc brakes tonight. Why? Who knows, but I couldn't sleep It's 1:37am, and I have to wake up in a few hours for work[&:]
I put the caliper in, and put it all on the new wheel. There is a gap of about 1/5" (.2") between the wheel and the caliper. Is this too close, or do you think I need to grind down on the caliper?
I had heard some trick about wrapping the caliper 10x with masking tape, but not sure if that is really a good test, or just a guess
Old Jul 27, 2007 | 02:27 PM
mySAVIOReigns
Default RE: gap between wheel and caliper
Anyone?
Old Jul 27, 2007 | 03:43 PM
groho's Avatar
groho
I was trying to locate the response from SSBC when I put on my front discs. I believe it was a min. of .25" (qrtr in.) between the outside face of the caliper and the inside face of the wheel. I too had to grind off material to add clearance. The good news, there's plenty of material so you shouldn't need to worry about hitting a passage, and a good coat of caliper paint when your donemakes the calipers look brand new.Stay away from wheel spacers!
Old Jul 27, 2007 | 05:37 PM
mySAVIOReigns
dang...I don't know my exact width, unless I use a benchmark. I guess I could stick something down in there that fits, and measure it. I hope it's .25. Thanks,
Old Jul 27, 2007 | 07:12 PM
JamesW's Avatar
JamesW
If the wheel bolts up over the caliper, spins freely and doesn't touch... don't worry about it.
Old Jul 27, 2007 | 07:35 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
The Irish guy, Plenty O' Room says you're all set.
Old Jul 27, 2007 | 08:08 PM
mySAVIOReigns
Old Jul 28, 2007 | 04:26 PM
MakiMaki's Avatar
MakiMaki
I just went through this with a new set of styled steel wheels, and discs up front. Its pretty much as easy as everyone is saying...... Just grind down a bit of the caliper, also make sure the wheel itself doesnt have an ugly weld sticking out, i had a few welds on the wheels that needed a light grind.
"If the wheel bolts up over the caliper, spins freely and doesn't touch... don't worry about it."
"Stay away from wheel spacers!"
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
