tachometer
Old Aug 4, 2007 | 06:49 PM
cole18cars's Avatar
cole18cars
Default tachometer
I have a 66 289 2v with automatic trans, Pertronix I ignition. I was thinking about purchasing a aftermarkettach [ too cheap for a ralley pack]. What type will work with this setup? I only ask for setting idle etc. It would be column mounted, not in the dash. Thanks
Old Aug 4, 2007 | 06:52 PM
gothand's Avatar
gothand
Default RE: tachometer
Just about every tach I've seen allows for hookup for either a voltage trigger or a current trigger. In other words, probably any aftermarket tach you buy will work with your car AFAIK.
Old Aug 4, 2007 | 07:00 PM
Mustangdemon67's Avatar
Mustangdemon67
i have a new monster tach for sale if your interested. i decided i want to go with this one, cuz i think it looks better since its a classic
Old Aug 4, 2007 | 07:25 PM
cole18cars's Avatar
cole18cars
Looked at a Sunpro from JC Whitney for 39 bucks, any good?
Old Aug 4, 2007 | 09:26 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
All of the aftermarket tachs I have seen are
Green wire = (-) neg. coil
Red wire = hot
Black wire = ground
Blue wire = lights
Unless of course you are running a factory Ford tach and then that is a whole different
animal all together
Old Aug 4, 2007 | 10:56 PM
JamesW's Avatar
JamesW
The little SunPro Column mount tach like below can be had for cheap at places like Autozone.
Old Aug 5, 2007 | 07:12 PM
cole18cars's Avatar
cole18cars
Thanks. Has been ordered. Hope I don't have to post when I try to hook it up.
Old Aug 10, 2007 | 09:04 PM
cole18cars's Avatar
cole18cars
OK, got the tach, mounted on the steering col etc. This is my plan for hooking up the wires. Black to the ground from the engine to the fire wall, green to the neg side of the coil, white to my instrument lights. Red to? I have a Pertronix 1 hooked up after the pink resitor wire. Can I hook up to this wire, or will it interfere with the Pertronix operation? If so, where is another point to attach the red wire ?
Old Aug 10, 2007 | 10:21 PM
dcohen's Avatar
dcohen
hook the red wire into your switch, that way its got juice when you turn on the switch
Old Aug 11, 2007 | 03:21 AM
groho's Avatar
groho
just hooked mine up today, red to switched power, green to neg distr coil, white to dask light, and black to ground. piece of cake.
93rustanglx
Sep 20, 2006 10:36 AM
elmustang5.0
Jun 17, 2006 12:55 AM
fle5141181
Jun 7, 2006 12:59 PM
cletusboyer
Feb 10, 2006 12:41 AM
92FordGt
Oct 31, 2003 09:35 AM
